It works on Pi4. Broadcom armv8. This is from the Grafana community:Another issue that somebody might run into and spend half a day not being able to solve.
Grafana will not run on the latest Raspberry. It is built for ArmV4, and the r-Pi is built with an ArmV6 processor.
Exactly what I did. Doesn't work on the latest Zero. Influxdb 2.0 doesn't work on the latest Zero, either, though some people have tried to make unofficial builds.You can get it here:
Download Grafana | Grafana Labs
Overview of how to download and install different versions of Grafana on different operating systems.grafana.com
Or just:
wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
and then use apt.
Exactly what I did. Doesn't work on the latest Zero. Influxdb 2.0 doesn't work on the latest Zero, either, though some people have tried to make unofficial builds. I used the latest version of the lite OS. But, was not able to get that to communicate with any USB hub I have, and you need that to works the NOOBs interface. So I resorted to pre-installing the lastest OS onto the SD card and enabling the WiFi for a CLI interface.
the latest Zero
root@p-zero:/opt/SolarShed# ./RenogyWanderer.py -d
sys.argv[0]: Debug: enabled
## Diagnostic output from minimalmodbus ##
Minimalmodbus version: 1.0.2
Minimalmodbus status: Production
File name (with relative path): /usr/local/lib/python3.7/dist-packages/minimalmodbus.py
Full file path: /usr/local/lib/python3.7/dist-packages/minimalmodbus.py
pySerial version: 3.5
pySerial full file path: /usr/local/lib/python3.7/dist-packages/serial/__init__.py
Platform: linux
Filesystem encoding: 'utf-8'
Byteorder: little
Python version: 3.7.3 (default, Jan 22 2021, 20:04:44)
[GCC 8.3.0]
Python version info: sys.version_info(major=3, minor=7, micro=3, releaselevel='final', serial=0)
Python flags: sys.flags(debug=0, inspect=0, interactive=0, optimize=0, dont_write_bytecode=0, no_user_site=0, no_site=0, ignore_environment=0, verbose=0, bytes_warning=0, quiet=0, hash_randomization=1, isolated=0, dev_mode=False, utf8_mode=0)
Python argv: ['./RenogyWanderer.py', '-d']
Python prefix: '/usr'
Python exec prefix: '/usr'
Python executable: '/usr/bin/python3'
Long info: (none)
Float repr style: 'short'
Variable __name__: minimalmodbus
Current directory: /opt/SolarShed
Python path:
/opt/SolarShed
/usr/lib/python37.zip
/usr/lib/python3.7
/usr/lib/python3.7/lib-dynload
/usr/lib/python3/dist-packages
## End of diagnostic output ##
Details of the serial connection:
Renogy: minimalmodbus.Instrument<id=0xb66d1ad0, address=1, mode=rtu, close_port_after_each_call=False, precalculate_read_size=True, clear_buffers_before_each_transaction=True, handle_local_echo=False, debug=True, serial=Serial<id=0xb66d1b30, open=True>(port='/dev/ttyUSB0', baudrate=9600, bytesize=8, parity='N', stopbits=1, timeout=2, xonxoff=False, rtscts=False, dsrdtr=False)>
Opened new tmp file /ramdisk/Renogy.prom.tmp
Reading Renogy Wanderer data...
MinimalModbus debug mode. Will write to instrument (expecting 7 bytes back): '\x01\x03\x00\n\x00\x01¤\x08' (01 03 00 0A 00 01 A4 08)
MinimalModbus debug mode. Clearing serial buffers for port /dev/ttyUSB0
MinimalModbus debug mode. No sleep required before write. Time since previous read: 617335.48 ms, minimum silent period: 4.01 ms.
MinimalModbus debug mode. Response from instrument: '' () (0 bytes), roundtrip time: 2003.3 ms. Timeout for reading: 2000.0 ms.
Failed to read from instrument
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyUSB1'
Plug in the device and run the command 'dmesg' - see what /dev/ttyUSBx it presents. Could be /dev/ttyUSB0 or whatever. Change that port name in the code.
Is the problem solved?I'm having this same problem... I'm sure my pinout is correct, but am not getting any data from the device. I modified Renogy_Wanderer.py to be device 255, and apparently minimalmodbus.py has been updated:
pi@bounder:/usr/local/lib/python3.7/dist-packages $ grep SLAVEADDRESS minimalmodbus.py
_BYTEPOSITION_FOR_SLAVEADDRESS = 0 # Relative to (stripped) response
responseaddress = ord(response[_BYTEPOSITION_FOR_SLAVEADDRESS])
SLAVEADDRESS_MAX = 255 # Allows usage also of reserved addresses
If you have a Bluetooth adapter, check the ID part below in the Renogy BT app. What kind of ID do you have? Is there a difference between a Rover that works correctly and a Rover that doesn't respond?First of all, I appreciate your response.
You're too quick! I changed the port to ttyUSB1 to check and see if I was simply not communicating with the port. I did get very different output, as I expected to see. I trimmed that part out of my post, obviously before you read it!
In the correctly edited output you'll see that I'm working off ttyUSB0 and sending traffic to the port but getting nothing in return.
Code:Reading Renogy Wanderer data... MinimalModbus debug mode. Will write to instrument (expecting 7 bytes back): '\x01\x03\x00\n\x00\x01¤\x08' (01 03 00 0A 00 01 A4 08) MinimalModbus debug mode. Clearing serial buffers for port /dev/ttyUSB0 MinimalModbus debug mode. No sleep required before write. Time since previous read: 617335.48 ms, minimum silent period: 4.01 ms. MinimalModbus debug mode. Response from instrument: '' () (0 bytes), roundtrip time: 2003.3 ms. Timeout for reading: 2000.0 ms. Failed to read from instrument
If you have a Bluetooth adapter, check the ID part below in the Renogy BT app. What kind of ID do you have? Is there a difference between a Rover that works correctly and a Rover that doesn't respond?View attachment 55299
grafana-cli plugins install grafana-clock-panel
grafana-cli plugins install briangann-gauge-panel
grafana-cli plugins install dalvany-image-panel
grafana-cli plugins install innius-video-panel
Inconsistency detected by ld.so: dl-lookup.c: 948: _dl_setup_hash: Assertion `(bitmask_nwords & (bitmask_nwords - 1)) == 0' failed!
for cell in range(dataStart, dataStart + 32, 4): # Change 32 to 96 to support the BMS16
getChargeryData.py
Hi, this is a really cool project, and I hope to contribute to it.
I've got most of it working, but am stuck on how to get prometheus to automatically launch on boot.
The cheatsheet says: "Add prometheus to systemctl so they start automatically at boottime"
How do I do that?
TIA
