My main service panel is 125amp and I have grid tied solar with net metering agreement. With 120% rule, I believe I am out of compliance with my backfeed. 125amp bus bar x1.2 minus 125amp breaker = 25amps of solar. With my 21 panel enphase system, I have 34 amps of backfeed. I know I can either derate my main breaker to 100amp (125amp x 1.2 - 100amp breaker = 50 amps) or get a bigger panel bus bar to solve that problem. What I’m unclear on is how to add an off-grid system that will supplement my current system while not backfeeding the grid. At the same time, I’d like the ability to use my current panels (in addition to the new ones), should the grid shut down. My main panel is already maxed out and I will be trying to add an EV to the mix as well! Upgrading to a 200amp service isn’t an option either, so I think I’m stuck with an independent off grid system that can use grid power if necessary, but not backfeed. Also something that will help lower the draw from the grid
