Hello all,
Well I am preparing to put my system together once I gather all the necessary components.
Looking at getting some 395w jolywood bifacial, and run those 4s3p in two strings. (9480w total, overpaneling by 35% OR maybe I will get another mppt...and/or stagger the east to west sun 50/50)
Only picked these because its the highest capacity local panel out there for a reasonable price ( no benifit from the backside)
On order, off the coast of sweet sweet california somewhere, is a Growatt 12kw 250v 7000wk unit with my name on it.
Also embarking upon the shipyard should be three jakiper 48v LifePO4 batteries.
All that aside, there are some things to consider.
First, I do have grid power available at 100amp service but I plan on just running pass through from a sub panel in times when there is no sun.
What I want to do is run the AC output of the inverter to the circuit panel of the building. What is the preferred method of doing this?
Im thinking a 'main breaker' panel would make more sense, but I guess it really doesnt matter. IF I get a larger panel AND its a 'main lug', I just wont use the lugs.. What size breaker/wire do people use for their output from the inverter?
As far as the array goes, I do believe I am on the right track but still some un certainty with a couple things.
Like I said 4s3p is 30amp at 200v . From what I understand, without a combiner box, I need to put mc4 20amp (panel rating) fuses on each series string, and then after i parallel, that string is going to pass through a DC disconnect at the array. Using 150ft of 8awg thhn to run inside and pass through a dc 32amp breaker and into the 2 pv inputs.
I've got 2 places I intend on sinking a grounding rod: at the array; and at the indoor panel. Do those 2 grounds need to have continuity by means of an additional wire to run from the array to the panels?
Is there any other safety Compenents I may be missing? The batteries have built-in breakers. The array is grounded, has fuses, breakers. And the panel will be grounded.
Additional info:
Jolywood
395W
VOC 49.03V
Isc 10.31amps
located in Georgia, USA
Additional info:
Jolywood
395W
VOC 49.03V
Isc 10.31amps
