Hey Everyone!
I'm helping my parents build out a battery backup system for their off grid cabin and wanted to see if I could get a sanity check on components and a few questions answered if anyone has the time. The first round will just be a battery/inverter charger and then we will add solar later (I know that's probably blasphemy here but gotta start somewhere
). But this will get them to the point where they don't need the generator running all the time to keep their fridge cold.
Background/Goal
Their cabin has been a slow project that they started about a decade ago so all the appliances are relatively new and pretty much any that can run on propane. The biggest critical loads that I can think of are the refrigerator, well pump, washer/dryer(propane), and keeping the gas fireplace online and running (Probably not that much its just a fan and some circuit boards). Other loads would be microwave/coffee maker/power tools for short periods or relatively small loads like lights/phone chargers/etc.... For reference they have been using a gas generator (8 or 9 kw I think) and it has been sufficient other than when they have a lot of loads like power tools and appliances all go at the same time but that will be happening less as most of the bigger building tasks are done by this point.
The goal is to have a reliable system that will work for lots of years and be simple for them to use when they arrive. I don't want them to get fed up with it and regret the purchase because turning it on/off becomes a hassle. Also has to be simple enough that other people who visit the cabin when my parents aren't there can either follow written instructions on how to turn it on can.
Main Components
Generator: 10kw Generac Propane Generator (My dad has already purchased this)
Battery: EG4 Indoor Wall Mount (280ah)
Inverter/Charger:
Option 1: 2 x Multiplus II 48v 3kVA
Option 2: 2 x Multiplus II 48v 5kVA (This one and then Option 1 are the primary options)
Option 3: EG4 6000xp
I would also be adding a Cerbo GX and getting that setup to autostart the generator if that matters.
Questions/Concerns
Background/Goal
Main Components
Inverter/Charger:
Questions/Concerns
- Would one EG4 Indoor Battery be enough to sustain the 2 5kVA Option 2 above?
- I initially though yes but then my brain has been nagging at me that it wouldn't be able to sustain the surge amps that the 2 inverters would be capable of with an appropriately sized battery and I'm wondering if there is any safety issues if that is the case or if I just would have less surge capacity but be fine on continuous output power.
- Do I need a DC Breaker/Fuse in between the single battery and each Inverter or is the 2x125A dc breaker on the side of the battery sufficient?
- Anything else I'm missing?
