renewablejohn
- Mar 31, 2022
- 2
Maybe the warning of the construction of a potential bomb came to late.We last heard from WillyP near the end of May 2021.
Wondering how they did with solar heat storage.
Why would you want to pump it when it is cold?Oil will be much harder to pump when it gets cold.
I read all of this, and I wonder, what about a closed loop of heat transfer liquid? (I do realize that some oils have a lower specific heat but much higher boiling and flashpoint). SO--how about just a solar collector and a 375F tank of oil in the basement and a radiator (if necessary) next to the tank? Seems like a single pump would suffice, and once that tank was heated up, it would be an enormous heatsink for a lot of cloudy or dark hours, supplemented by a backup source, if needed. I imagine a large tank of 375F oil in the corner of the basement and a pile of stone would be a great source of warmth up through the house.
You could build a sand battery, and use a heat exchanger with water to extract the heat.
Thermal energy storage - Wikipedia
en.wikipedia.org
Cheaper and safer than hot oil, no leaking.
LOL! I'm still here. Don't be sendin' DHS to the house yet. I did get delayed due to a car crash. I won't be building anything for at least another year. But I am healing and growing stronger.Maybe the warning of the construction of a potential bomb came to late.
that would work. But I am designing a system tht will actually heat the house all winter. I'm not looking to supplement a different system.I read all of this, and I wonder, what about a closed loop of heat transfer liquid? (I do realize that some oils have a lower specific heat but much higher boiling and flashpoint). SO--how about just a solar collector and a 375F tank of oil in the basement and a radiator (if necessary) next to the tank? Seems like a single pump would suffice, and once that tank was heated up, it would be an enormous heatsink for a lot of cloudy or dark hours, supplemented by a backup source, if needed. I imagine a large tank of 375F oil in the corner of the basement and a pile of stone would be a great source of warmth up through the house.
you do make some great points about the cost of PV solar. But I really really want radiant floor heat. I will get my electricity from PV solar. It will run the AC.Pumped solar thermal systems used to be the big thing a few decades ago, and we all know the problems of boiling and freezing, constant maintenance, leaks and so on.
Technology has come a long way since the old days, heat pumps are now vastly more efficient, and solar panels and batteries have improved as well, and come down in cost.
Water is pretty difficult to beat as a cheap non toxic bulk thermal storage medium.
These days, a solar/air sourced heat pump working into a large water thermal storage, powered from solar panels, might be worth investigating.
It sounds like a really poorly designed system. I really don't think keeping water at a certain temperature is all that hard. Especially if I use heat exchangers and a discharge tank. My system is designed to be under ground, inside a greenhouse with an insulated bottom. I could see some over heating as a problem. But not enough to render the system unusable.I have some practical experience with a fairly large (25,000 gallons) solar powered hydronic heating system that was installed in a school.
Your hope of maintaining a constant water temperature is hopelessly impractical.
Any heat added or removed from the storage will greatly change the water temperature, and its that temperature change that represents the useful energy. The greater the temperature swing, the more energy is stored/released per unit volume.
You quickly reach the point of either of boiling, or the water cools so much its not hot enough to do anything useful with.
Its all very well to say increase the volume of water, we had a tank about twenty five feet high and about fifteen feet in diameter (from memory).
It was HUGE.
But it really needed to be about five times that volume to work the way it was supposed to work.
I was not involved in the original planning, that was before my time, but I was the poor bugger that had to monitor the project and maintain it.
It simply did not work, and was ripped out and replaced with heat pumps a few years later.
I suggest you do all the thermal calculations before you spend a single dollar.
The tempering valves are usually used in gas fired systems. Or at least that is how I understand it. In a closed system, the water doesn't cool when some of it is removed. The only way that would happen is, if the cold water was returned to the storage tank. I plan to have a discharge tank that will store the cold water, then heat it before returning it to storage. Of course the storage could cool if it wasn't kept at a constant temperature. But being buried in an insulated vault should keep it warm.Sure, you can keep water at a certain temperature. All you have to do is put in exactly the amount of energy lost.
That is like keeping decoupling capacitors at a specific voltage. Easy enough, but they provide absolutely zero energy storage. Only by cycling in voltage (temperature in the case of water) do you get to store/extract energy. With the exception of phase-change materials, but many of those work over a temperature range. Ice in water is one with a set temperature.
You could use a hot water tank plus tempering valve to deliver constant-temperature water.
Yes it was poorly designed. It was planned by the Public Works Department for a newly built "energy efficient government school" built with state government money. Lots of publicity, politicians making speeches, media fanfare the whole works.It sounds like a really poorly designed system. I really don't think keeping water at a certain temperature is all that hard. Especially if I use heat exchangers and a discharge tank. My system is designed to be under ground, inside a greenhouse with an insulated bottom. I could see some over heating as a problem. But not enough to render the system unusable.
