I have NEVER seen any wiring like this.
It looks like brown romex with2 conductors inside... but no jacket on the conductors... they appear coated in tar or something.
the conductors appear to be about 18 gauge copper, but they are STEEL that is copper plated.
The outer jacket has cotton threads in it.
I will post up pics in a second.
anyway, I got called to inspect the home for the buyer, to follow up the home inspection. Found several code violations, and crazy stuff... a 120V hot tub plugged into a 20Amp outlet right outside the tub! (At least it’s was hooked to a GFCI breaker... but it was wired wrong!) the outlet was installed in an indoor metal box stuffed inside a two gang bubble cover, but it wouldn’t close...ugh!
i also found light switches and A SUB PANEL INSTALLED ABOVE THE BATHTUB...
But the wire I found hooked to a back porch light, stuffed through the facia board, wire nutted to some ceiling fan wires... stuffed into another indoor metal box, with a porcelain Edison base light fixture...
if anybody knows what this wire is used for I’d love to know...
oh... the house was built in 1900...
