I've never given much thought to these particular "function settings" section, but I've recently installed a heltec active balancer, and disabled the bms balance function to monitor and evaluate. But what exactly are these first 2/4 items?
1. Switch function??
2. Load check??
3. Balance enable..I get this one..on or off.
4. Charge balance? I "think" this means that when enabled, balancing ONLY takes place while charging, but when disabled, will still balance if the voltage is above the balance trigger point? (In my case, balancing kicks in at 3.4V) So essentially, it will burn off the highest cell(s) down the line until the set balance precision threshold is reached? (In my case 0.02V)
Am I close to being right here?
(I'll get into the "reset capacity" button later on)
Thx!
2. Load check??
Thx!
