Older Growatt SPF 50000TL HVM Without BMS/CanBus/RJ45 Port to connect LI batteries
Basselaz
Hello...
I have an older Growatt SPF 50000TL HVM that doesn't have neither a BMS or a CanBus or an RJ45 Port... I currently have two inverters connected in parallel for 10Kw output and Flood Lead Acid batteries
I want to upgrade to Lithium but found out that i have none of the above ports for safe communication with the batteries. Is there a way to connect Lithium batteries safely to my current setup? Adding external BMS or something? Any support will be appreciated
Bassel
Thanks for the clarification... But why then do the new inverters have these bms ports in them?
