In 2014, i installed a 200 Watt panel, feeding a MPPT T20 controller feeding two Deep Cycle Marine batteries (845 CCA, lead acid, circa 2015) feeding a 1500 watt inverter, NOW feeding a new 20 cubic foot deep freeze (531kw/yr). My question is, since this will be the first time I have powered anything from, it, I want to be sure the MPPT is set properly. See Attached file. Any help will be appreciated. If I can get this sorted, and it works, I plan to power two of these freezers, on timers, so they are not both powered at the same time. Like during a given hour, power one for 45 minutes, and the next hour power the other for 45 minutes, so there are gaps between the two charging events. It is my understanding, that if not opened, the freezers cycle 5 minutes per hour. Not sure if that is true or not. I am NOT a electronic genius, and 75 years old, so be gentle...
