I have two DIY 4S LFP 280Ah packs in parallel (560Ah) in my van, each with a 120A Overkill BMS.
These are Eve cells purchased from Basen. I did top balance the cells when I received them, but only tested the capacity at 40A, as I believed I would very rarely be drawing more than that (I have propane for cooking).
It has been working great so far, with the cells staying together. The idea of this project was to last several days, and the batteries are doing the job. I even have to disconnect the chargers so that they don’t stay at full charge all the time.
Now with all that power, I decided to try a 1500W portable induction cooktop. Before I turn it on, all the cells are at 3.33V with a delta around 0.005V on the BMS app. When I do turn on the cooktop, the first cell of each pack drops much more than the others, one around 2.9-3V and the other at 3.1V. When I turn it off, the two cells voltage increases to almost reach the others.
It could be that these cells have lower IR. But since this is happening to the first cell of each pack, I am thinking it could be something in my setup... Any idea as to what could be causing this?
