NomNomCameron
- Mar 25, 2020
- 28
I have 300 watt pannels connected 4 in series per string going to a combiner which feeds an EPEver 100 amp 200v charge controller. I started connected the strings today, first 2 went off without a hitch, showing 20 amps @ ~150v, when I connected the third string the amperage did not increase on the charge controller and when I check the current around that string (where it connects to the combiner) the amperage is showing opposite polarity of the other 2 strings? This third string in question shows ~150v when probed with the same polarity as the other 2 strings and I have triple-checked that all strings are wired in series correctly all the way to the combiner. I connected another string the same way, without an issue so this problem seems to be isolated to this string. Could one of the panels be bad or could I have done something wrong??
I've never run into this issue before with new or used panels (these have never been used, purchased at a liquidation auction).
Any help on this would be greatly appreciated!
