NewGuyNoob
- Jul 30, 2021
- 98
I moved this thread from General Discussion:
Hey Guys/Gals,
I have a background in a lot of different things, but not much in electronics
I plan to install this system below, I have already purchased these items below, but I go to physically pick these items up tomorrow.
1 x Growatt 12K offgrid Inverter
20 x 72cell 370W Rene Sola Panels
2 x Gill 48v LifePo4 5kw Batteries
Question: If I wire these as 5s2p (each string, total of two strings in my system) my Open Circuit Voltage is approx 240 volts (each MPPT is max 250). Should this be calculated as Open Voltage or Max power Voltage?
Also, I am aware there is a coefficient for cold weather and I could go beyond this threshold, so If Open Circurt Voltage, then I have to reduce this voltage, but if based on max, then it would be approx 219v, which I feel is safe. I plan to use 10AWG PV wire, the run will be approx 130/150ft away. Ground Mount installation, temporary as I am in my homes build site, in a fifth wheel.
Question: The gyll battery uses 6AWG to the battery "rack" busbars, which I do not own. What AWG gauge should I use to parallel these and connect to the Inverter? I have 00 gauge wire which is probably overkill, My use at the moment is not 12KW, about 5/6KW is my planned usage if running my two A/C's (13btu, 1500btu, 120V/15 amp) Generally speaking, I plan to use one only, maybe two for testing the system out. But that is alot of energy usage.
Question: The Growatt 12K inverter, what size are the battery terminals? 6mm? I could not find this in the User Manual or Spec Sheet. Does anyone know? I really need all the sizes actually of the terminals so I can purchase the proper wire sizes and end terminals.
I am new to this entire solar thing, I have completed research for a while now, but I have some many questions and this forum seems to be a wealth of knowledge. So feel free to offer any advice as well!
Thanks!
Ok, So,
I've installed the Growatt 12K and 2 new Style Gyll 5KW, I used 2/0 welding cable (these have the lcd screen for viewing BMS Data).
I think I should have used 4/0 to connect the batteries? suggestions? The distance is 6ft from my batteries to my inverter.
Also, I have a 60Gallon air compressor that will not run. I think this is because of the induced surge load, maybe 4/0 will help?
Where my Solar Panels are positioned now, I get 219 volts to the MPPT's, which is full sun. I will eventually have to move these panels, as they are installed temporary, laying on the ground, (propped up approx 10 degrees), because in winter the sun angle will be too steep to reach these panels.
As I'm in process of clearing an area for my solar arrays, I plan to grow my solar system (with racking) as needed over the years. I am also looking at breaking out into a solar -modular- design at a later date, the all-in-one is easier to start the journey IMO.
I live in a construction zone for my new home, In North Alabama. I have 20 acres all wooded, and I am currently living in a 42ft fifth wheel. I plan to build in the next year or two.
I have 20 of these Solar Panels:
ReneSola JC370S-24/Abpw, (72 panel)
Maximum Power (Pmax) 370w
Open Circuit Voltage (Voc) 47.8
Maximum Power Voltage (Vmp) 39.9
Maximum Power Current (Imp) 9.28 A
I have these set up as 5 in a series and then paralleled into another 5 panel string, so 10 Panels totaling 219 volts, to one of the MPPT's and another exact same 10 panel string, as stated, to the other Growatt MPPT (Growatt 12K has two MPPT's). The max sun, and maximum panel output, I get 5.5KW of power to the MPPT, combined from both strings. The current distance from my panels to the Growatt is 200ft, I used 10AWG solar rated wire.
I am in the process of trying to figure out what is the best solution for a software monitoring application. I need to connect wirelessly from the "shop" approx 50' away to the camper, my internet connection is also wireless. I would like something that has an iPhone application/web interface. I have been looking into https://solar-assistant.io/. I have a laptop dedicated to capture data from the growatt (I do not want to use their app or their cloud service).
Solar Assistant is for Raspberry Pi, I have thought about using Virtual Box (https://www.virtualbox.org/) and then installing this on my laptop, as I rather not purchase new hardware for this purpose. The basic idea is this: https://thepi.io/how-to-run-raspberry-pi-desktop-on-windows-or-macos/
Since I receive 5.5KW in my current configuration, would it be safe to add another 1.5kw to the Growatt MPPT's? I would expect the MPPT's to clip the extra amperage if I go beyond the 7KW allotted (120amps). Is that a reasonable expectation? Obviously not exceeding the 250V to the MPPT's.
Also, I have my g4ll batteries connected to the growattt BMS service. I am just waiting for the Growatt WiFi dongle.
Thanks!~
Hey Guys/Gals,
Thanks!
Ok, So,
Thanks!~
