wlai
- Jun 1, 2021
- 2
Hi:
I'm trying to buy the right tools and connectors for building solar PV system. Going to start with a system for my boat, and then work my way up to a home system. I've tried the Closed Barrel terminal when I was building a cable for my car, but it required borrowing a hydraulic crimper from a friend. Not knowing what I was doing, it came out "wonky" as the wire wasn't thick enough for the barrel, I crimped too hard, and the crimp came out lopsided and ugly, and the barrel metal actually tore. It held up ok so far but I am sure it was either technique or the barrel not being the right type.
I'm wondering if Open Barrel terminals can be used instead? It seems easier for me, doesn't require a hydraulic crimper which is easier for me to judge how well it's crimped. Is it any less secure?
And can you recommend me the best connectors and crimper to get, with links? I dont' want to blow my budget on the crimper so Chinese ones or HF ones are my budget point. Thanks!
