Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
I am not familiar with Batrium BMS' and their various components, I do know however that they are not cheap and could be considered Tier-1 Premium grade goodness. I peeked at them but the $$$$ made me go elsewhere and I landed on Chargery BMS.Thanks for your valuable inputs.
I'll do some reading / further own investigation on this question, but here it goes: Could I connect my Batrium BMS to your proposed configuration? If I buy 16 additional blockmons (I already have 16), could I use them with just 1 Batrium WM4 + 1 shunt, or would I need go for two Batrium's and Shunts (ie, 2 complete BMS's)?
I understand your point of view, and know that by paralleling cells in pair, I'll lose the ability to monitor each single cell individually. But since people are paralleling (many) dozens of used 18650 cells and monitoring them as an whole, I thought that pairing only 2 new (although bigger capacity) cells wouldn't be a problem.
I also asked Xuba por a quote. Amy was super nice, but their quote as around $700 more expensive than what I ended up paying.
I bought my cells at $95 each, including S&H with all taxes and fees (34 cell order; bought 32+2, for redundancy/testing).
Advertised as grade A, new cells.
Li-ion 18650 Cells are somewhat of a different animal altogether as is their assembly into packs and the methods used for fusing & bypassing dead cells. It isn't quite the same, similar yes but not the same.
"Technically", it's not a problem and it works and if using new fresh matched & balanced cells it will last BUT (yep, there are but's) IF / WHEN a cell starts to show it's age and they will, at separate times over their lifespan in the pack, this is where the troubles will begin to appear and the pack will deteriorate. When that will happen all depends on the loads, cycling and the individual cells chemistry & effects on them.
The ShunBin pack I bought became an expensive educational experience pack. It came as 24V/350AH (was supposed to be 400AH) and they used 174AH cells paired, just like you are doing. They ghosted weak cells in with good ones and tossed a crappy 8S BMS on there and called it good. NOT AT ALL GOOD ! I rebuilt it as 8S and replaced the aluminium garbage bus bars etc to make it right and no way.... I will now have to split it into proper 8S 174AH packs and replace the 3 weaklings I got saddled with.... even worse was they are at Best Grade-B but most likely used cells and used hard no less.
