jameshowison
- Jul 30, 2021
- 184
Fuse Battery to busbar. Any shutoffs.I guess the only items that would need to be 60v rated would be everything from the Mppts to the inverter right?(breakers fuses etc).... if the inverter/mppt's take a shit im up shits creek anyways right? so having a back up breakers/fuses items of that nature would be smart to have on hand.
Fuse between Busbar and mppts
Fuse Busbar to inverter.
You are right that the lower amperage part is the MPPTs. Usually 30 or 40 amps. Options are mbrf, midi, or there may be a littelfuse mega 58v someone linked recently.
I had a 48v DC aircon as well (hotspot mini split), which was 30amp fused.
Unless the cable run is long, the components and labor time outweigh the savings, I reckon.
And yes, very likely camper stuff can all run on 24v, including fridges and inverter. Cheap 24-12 if needed for some things that don’t run on 24v. Can then do alternator charging as well (12-24).
