Paintedsky
- Sep 12, 2020
- 10
I am getting ready to complete my off grid solar power system on the Big Island of Hawaii...I have 64 brand new 280 amp grade A matched LiFePO4 batteries, and will be configuring them in a 4P, then 16S bank for 48 volts, I am planning on using the single Overkill Solar 16s BMS to manage each group of 4 batteries that are in parallel. do you think this should work alright? .......Also, I have been trying to complete a top balance on the entire pack of 64 all connected in parallel. all of the batteries were at 3.29 volts when unpacked, and after two weeks of charging from my 10 amp charger, they have increased to 3.35 volts, so I am wondering how big of a risk I might be taking by putting them into service without bringing them all up to 3.65 volts. I have the Growatt 12k charger/inverter, and am thinking about setting the Growatt charge max absorption to 56.4 volts, float to 55 volts, and cutoff to 48 volts....Also, not sure what gauge of wire I should use to connect the positive side of the battery bank to the Growatt.....Your thoughts on this would be greatly valued.
Thanks.....
Thanks.....
