I have purchased most of what I need but have not set it up yet as I am still several weeks away form the solar setup. Still working on a bunch of other stuff in my van build.
I need some feedback and advice on what I have purchased already as well as for possible other components and how to possibly overcome the idle drain of the inverter.
So far I have purchased a Jakiper 48V 100Ah server rack
A Growatt 48V 3000W all in one 3000 TL LVM
3 Jinko 310W solar panels JKM310M-60L for a total of 930W
Spools of pure copper 12ga and 16ga wire for van lights, fans, usb outlets, water pump, 12V aux plug, etc.
The van will hopefully be all electric, no gas or propane.
I want to run a 4.3 cu ft fridge.
I would like to install a LG 9000BTU 120V mini split for occasional use. In other words, I would not stay in a hot or cold climate where constant use would be necessary.
I will have an 800W microwave and an induction hotplate for cooking.
Sometimes I may want to use an electric mattress pad during the night.
I have a Maxxair 14" fan that will be used quite a bit.
I will need to get a converter to go from 48V to 12V. I don't know which to get. I don't think I will need a lot of watts at 12V.
I will get a 6 circuit fuse panel for the 12V.
For the inverter no load drain I have considered a couple of things. The inverter would need to be on for the fridge 24/7.
One I could get a DC fridge. But I don't want that. I like a more regular type fridge.
I could get an additional inverter for lower loads that has much lower no load waste.
But I don't know of such an inverter for a 48V system. Maybe I should have gone with a 24V system. More options are available for 24V.
Does anyone know of a 48V, low loss from idle/no load inverter that would work for this? Really it just needs to run the fridge. But it also needs to be able to handle the start up surge of the compressor of the fridge.
I also thought that maybe a timer that cycles the inverter on for 15-20 minutes each hour and then off for the remainder would cut down on the wasted watts considerably.
Also maybe I have enough solar that it will not even be an issue. 930W is quite a bit for a van. There is no more available roof space for more solar.
I would appreciate any feedback or suggestions or criticisms.
Any other suggestion as to what to incorporate into the electrical system design or solar design are welcome.
