Options for use with a neutral switching manual transfer switch?
jmart4173
TN
I have a Generac 6854 manual transfer switch running the critical loads in my house. I am using that particular model for its neutral switching capability which makes it compatible with my Ford F-150 Powerboost with the 7.2kw generator capability. It works very well. What I am looking for now is a battery option that can be used for shorter outages or if the truck is not at the house. I am open to a DIY route (hand truck build) or a solar generator like the Jackery 5000. I am struggling to find the best way of confirming those options would be compatible with the manual transfer switch.
Thanks,
Joe
Jackery support responded to me that the 5000 is compatible with a neutral switching manual switch. So now I am looking to understand if any of the DIY options can be made to work or are compatible. If I build a solar cart option and wire up the correct 30 amp plug to the AC output do any of the AIO options work with or without modification? When shopping for fossil fuel generators it is easy to search for floating or bonded neutral but this does not seem to be something highlighted by any AIO mfr.
You could just have a second transfer switch installed between the first one and the main panel. If you don't have the truck there and the need power you flip it and use a battery bank and inverter
