Right but my current increases as i start dialing up the voltage.Once current is as high as the PS can provide, extra voltage is pointless. And if you aren’t in the room when the pack hits “the knee” at about 3.4v you can bulge a cell in less than 15mins above about 3.7v, more or less. The higher the charge voltage the faster it happens and the worse the damage.
Capacity check you'd have to find something that runs at 3.6v. If you mean voltage check, pull psu leads, check in parallel.Configuration for capacity check, can I leave it as is, parallel, or should it be changed to the 12v configuration for the test?
Either works, but I prefer to do it as a pack since that’s how it gets used. You get a slightly lower number as a pack because the cells aren’t perfectly matched, but I haven’t found the difference to matter IRL, maybe 1-2AH. Just don’t be disappointed if the pack comes in a little lower than the cells.Configuration for capacity check, can I leave it as is, parallel, or should it be changed to the 12v configuration for the test?
That would be fine too but I wouldn't do it without the BMS connected. One would have to watch the voltage of each cell because over discharge could be a concern. With the BMS connected and the LVD set to 10 volts it would be fine. Also one could test the capacity of each cell which would probably be a good idea if connecting cells in parallel to make a pack. Having matched cells in parallel, or as close as possible matched wouldn't hurt.Or put them in series, right. Sorry, I'm driving.
RJ copied that information from Nordkyn Design. Permission was not asked to use it and this was confirmed by the author. Nordkyn has useful articles on their website. The information RJ copied from follows:Yes, likely will put them how they are planned to be used, in series.
Also, found the link to top balancing cells.
Maybe, want to give these cells a good test.A few mV off doesn't concern me. So you get 23 instead of 25 years out of the cell. Who cares. You're going to get hit by a bus before then anyway.
I agree with you. I am not going to take a chance on bloating one of my cells and that's why I will charge in steps. I will charge to 3.4, then 3.5, then 3.55 or 3.6. and consider it done. In addition I will not be relying solely on the power supply readings. I will be taking readings at the cells with a meter. I have plenty of time....no need for anyone to rush things.Maybe, want to give these cells a good test.
Also, not going on vacation until December, do not want to rush quality.
The cells should be periodically checked, balanced, proper charged, etc. as well. Exert some effort into maintaining them just as you would with regular vehicle maintenance and you'll be just fine. Things last for as long as you take care of them.I agree with you. I am not going to take a chance on bloating one of my cells and that's why I will charge in steps. I will charge to 3.4, then 3.5, then 3.55 or 3.6. and consider it done. In addition I will not be relying solely on the power supply readings. I will be taking readings at the cells with a meter. I have plenty of time....no need for anyone to rush things.
Hard telling not knowing.So how many more weeks on the charger til you're full?
