Originally was thinking of Anker F3800 or Jackery 5000. I then found Will's portable power station video and thought EG4 6000XP and server rack battery.
Now, thinking I don't have a need for 240 split phase as my home is almost entirely gas except for 4 ton AC; especially since the 6000xp is only 3kw per phase and no load balance.
Thoughts on Orient Power LV6548 6500w with Jakiper 5.12KwH server rack battery and pigtailing hot in panel to split to each breaker of a double pole breaker. Would turn off 240 breaker to AC prior to back-up use. This would provide 6500w combined across the 2 legs and not have load balance concerns.
The Orient Power set-up is $2222 including delivery.
Thanks for any thoughts.
