Justkeepitsimple
Gifted Orphan system
Hi all. I got gifted an orphaned system Im sorting through and reoptimizing into something more efficient/ useful. Was on a tradesmans box trailer for running light power tools. I think originally put together in 2008 -ish. See what you all think and need Help with battery Identification.
6V Nominal Sealed Lead batteries
External Marking stamps:
“ FA146VYK1A “ FA which I gather stands for “Factory Activated and sealed”
I think the “146V” is for 14.6V max absorption voltage (if accurate reflects they are AGM type?)
Google yields no close or exact match to anything that looks like the batteries in my possession.
“ RBO “ ?
And “ POS / NEG “ obviously.
Haven’t been in service for at least 6 months. Haven’t tried to run a load on them or charge them yet. Resting voltages:
6.29
6.32
6.41
6.53
At least 60lbs each
dimensions HxLxW 10”x10 1/4”x7”
Standard ASE Lead terminals and threaded auxiliary studs.
One case is getting bulgy. No sloshing when rocked so not flooded I think.
Worth putting into service? I am kind of inclined to core them out and get known good batteries of same new condition.
Run as 2S2P with 2/0 cabling with a 4/0 splice to the inverter.
One Single Kyocera 120 watt Solar Panel
Rated:
VOC 21.9
ISC 8.02
Still put out 21.5V on the multi meter seems minimal degradation but shattered glass . Bummer for a made in Japan Panel. Probably for the transfer station E-waste. Will save the mounting clamps/ rails.
Morningstar SUN SAVER PWM
SS-20L-12V
S/N : 08150183
12 Volt 20 Amp
The little gold nugget. Is an older version . I am thinking the most salvageable and useful bit of the system.
By chance anyone have a manual for one of this vintage? Morningstar has the newest version manual on their website got me the general idea but there are a couple differences between this vintage and the current version. I may have to email Morningstar customer support for that info.
XANTREX TR1512-120-60
SN: P10000772
Inverter/ AC battery charger
1500 watt 12V Inverter
120VAC 70 Amp Battery Charger
Manufacture date June 2008. Assuming the rest of the system is similar vintage. Batteries may be newer than that.
All the fuses and breakers are square D AC breakers and AC class T fuses of appropriate amperage rating but of doubtful usefulness on the DC side of the system. Was this a rookie mistake or common practice in the 2000’s?
I’m thinking of retaining the inverter/charger as an ocassional battery charger for the main system bank. It’s kind of a boat anchor for 1500 Watts of square wave AC.
I was thinking of making a smaller more optimized system (seems like solar charging capacity to battery capacity ratio was way too little). Maybe a mobile battery tender for vehicle batteries with a couple panels and the Morningstar charge controller? Or a dedicated small system with a 100Ah battery and and a Dc-Dc converter 12V to 56V DC to to run the Starlink system 24/7.
On the topic of Orphaned solar components does anyone have a spec sheet / manufacturer for these panels?
Got many for free. 12 Volt nominal system panels (still putting out 18 to 23 volts). I’ve seen them on many other older off grid systems in the area so I know at one point they were fairly ubiquitous available affordable (for the era). 40watt? 60 watt?
Dimensions: 1’ 1/4” x 3’ 1/4”. And that is all I know about them other than what they look like. No manufacture markings, or spec plate of any kind.
Thanks everyone.
“ RBO “ ?
6.29
6.32
6.41
6.53
At least 60lbs each
Rated:
VOC 21.9
ISC 8.02
SS-20L-12V
S/N : 08150183
12 Volt 20 Amp
SN: P10000772
Thanks everyone.
