Our NEW GO-TO LiFePO4 vendor...09.20.21
ghostwriter66
"Here - Hold my Beer"
I just got a quote, exactly the same price as shipping from Amy on alibaba in China, but they cannot guarantee you will receive the new LF280K version which is upgraded to 6000 cycles.
I decided to ship from China as i really want this new version with double the life. She infact suggested the same solution if I wanted the new version.
Not sure where you get the "double the life" from. From everything I read they are somewhat better - maybe - its hard to say since not allot of info about them ...
ghostwriter66
Hello dear, I heard you from Sam too. Thanks for your introduction of our products. I am wondering that there might be a misunderstanding that we only have the warehouse in Houston, no CA warehouse. Could you please help to fix that ? It would be highly appreciated ~
Fixed it ...
ghostwriter66
THEY DO NOT HAVE A LOCATION IN CA AS I HAD EARLIER THOUGHT THEY WOULD. ONLY HOUSTON. Which is a little bizarre since I would have done LAX for sure since that's where the batteries come in at and then I would have shipped from there as the hub .. BUT Houston is great for me.
RobertGreen
It's only double life because its tested at half the load
I really wish we had better data or even an apples to apples comparison between these different cells. I've read that "how" you run or cycle them makes a big difference in cycle life, and that there's a lot of complexities to consider when you're really trying to estimate calendar lifetime vs the operating conditions these cells will be seeing in real life. I've got some of the LF280K's and some others as well-- if these sets last 5 or 20 years it will be fine with me either way.
Pyrofx
Flux capacitor builder
The biggest problem I see is.......
People worry about shit to much. 302 , 301 , 303.3417624 ah.
To much time on their hands to make things to gripe about.
Sing of the times.
As for the sellers , it all a game of slight of tounge.
Do people go through all this crap with lead acid ?
upnorthandpersonal
Administrator
Sing of the times.
On one hand, yes, people spend a lot of time on this. On the other hand, having this kind of information being discussed means people can make up their minds and have realistic expectations when looking into buying these kinds of cells. After all, it's not like you can go to the nearby store for them like you would for lead acid...
tim0shel
You can always ignore the thread :)
In many ways, it's useful to dwell on things - if people have the time, why not.
Come to think of it, maybe I'll start a new compression thread to see what the current status and thinking is 😁
Thank you for sharing the thread and this supplier as I notice that other thread also with this same supplier. I was soooooooo close of contacting Amy via FB and going ahead ordering some then I was like nooooo. I have enough projects and new car in the works that I want to customize along with Christmas here before we know it so the budget is not currently in its best for justifying buying some.
Staying on topic I love to hear from others that purchase these and do capacity test.
jamiko
I think people look at the new datasheet that says 6000 cycles and compare that to the old datasheet that says 3500 cycles. They don't see that the new cycle life test is at 0.5C whereas the older test was 1C. My guess is the previous LF280's would also get near 6000 cycles if the test was done at 0.5C.
K8MEJ
16 x 280ah old model cells shipped from the USA was $2350, the new LF280K cells from China was $1950 door to door in 50 days.
The Alibaba link is in the first post.
50 days? I hope you're right. I'm at 101 days and still asking for tracking information and where my stuff is. I'm in Ohio. Since you're in Cali I would expect you'll get your stuff about a week faster since it doesn't have to ship ground across the USA. Good luck.
BarkingSpider
Carbon Lifeform
Did you purchase from the vendor in this link?
elvis_asaftei
I picked up 4 CATL 302ah cells from this location on Saturday and they tested 309,309,312 and 314. All pristine. IR was .21,.20,.21,.19 weight was 11.6lbs, 11.75lbs, 11.75lbs and 11.7lbs
Tests were one at 40 amps btw
Do they have any AliExpress store link where I can order from ?
