JustPractical
- Aug 31, 2021
- 106
I have four things to power (well pump, sump pump, fridge and oil furnace). Very unlikely all four would start at same time, but if they did, they would pull 92Amps and 11,100 watts. Am I better off going with the Outback Radian GS8048A-01 which can handle the surge better, or a pair of the MPP Solar LV6548 which can handle the starting current as part of their normal operation? Not looking for the paper specs answer (or the Growatt would be here too); more asking which is more reliable long term solution? The Outback will be pricier for one than the MAPP is for two (so I can get split phase). If the Outback I have mentioned here does not support split phase, then the Outback solution will be MUCH pricier. Thanks in advance!
