I don’t believe in maxing things out .Why stop at 25%? The SCC is only going to use what it can use. Does it care if the array can produce 10, 20 or 100% more than that?
I asked midnite solar about over paneling the classic 150 , and they told me it makes no difference. It will only use what it wants and the rest is wasted. It does not even disperse as heat, it just never gets used
It's like hooking up my 1500w toaster to the mega watt grid. The grid can produce many thousands of watts , but my toaster is only ever going to use 1500.
I’m hoping I don’t need the warrantee, my system is allmost 5 years old and it just works , I’ve been reading about a lot of people having problems with sunny island systems over the last few years .You could buy the Outback Flexpower and get a 5-year warranty.
Or SMA Sunny Island, 10 year warranty standard.
Not a pre-assembled panel, though. Pair with a Sunny Boy to connect PV (600Voc max strings), 10 year warranty, 15 or 20 optional
Together, about same price as Flexpower. (less if you buy somebody's inventory liquidation, maybe < $4000 for both)
You get combined AC wattage during the day.
But if you build a "small" system with just one Sunny Island, will require a 120/240V transformer.
If I needed more power I would just add a second charge controller
I’ve heard good and bad .
I was not really looking to save any money when I built my cabin the power was just a small part of the over all cost.
and I’m very happy with it .
I know 2 people that have out back equipment running one for 21 years and a second for just over 10 They just humm along .
I’m not a electrision and to pass code here I thought it was better to just have one working system
im not to worried about the warrantee.
I just look at some sunny island equipment and I’m seeing 5 year Warrantee ?
I may have miss some thing .
That’s a nice set up they where just coming out 4/5 years a go when I bought mine .I have a Outback GS4048 running a large ~7k sqft house without a problem. The Outback has many options and can AC couple with the firmware upgrade. I didn't buy the lower breaker panel and just made my own which saves a lot. I also right now a have 18 280ah cells connected so you can go above 48volts and add some capacity to your battery without buying a whole new battery.
Note on the menus.....Outback displays everything in the Mate3 even if it isn't connected so just go to the menus of the stuff you have connected. Like if you don't have a solar charge controller from outback there will be settings in the Mate but they will do nothing.
Good Luck with your setup.
Asphalt shingle roof. I saw the mini rail - but we get a good bit of wind and snow, so I was spooked.I'm partial to Prosolar racking with your whatever needed type roof mounts. Dollar for dollar you can't really even DIY Rails for the price of a Prosolar rail. Unistrut is another cheap option but its only slightly less than Prosolar and u can run into the issue of what to use for end caps.
S5 makes a great line of roof mounts. I've used the versabracket 47
Signature Solar makes a budget friendly mini rail but honestly I look at it and think, how exactly do I do zip tie cable management with these?
Hmmm this is a very interesting ideaTwo strings of panels, oriented differently and wired in parallel, would max out hours of production rather than peak watts (and heating).
Going by trigonometry, aimed at 9:00 AM and 3:00 PM sun, 6 hours and 90 degrees apart, peak should be about 0.7x what all same orientation would have delivered.
That’s looking scary , my out back is very nicely doneGo with Outback. MPP are very poor build quality as I showed in another thread.
I bought an MPP LV48 3Kw unit about a year ago, and it's worked flawlessly, but I was not so lucky with the second one I received about a month ago.
I ordered the parallel boards at the same time but there was a problem with delivery, so I installed it as just an MPPT charge controller to my battery bank. Turned it on and the first thing was an error code that the fan wasn't turning. By careful examination (I stuck my finger in the fan) I could fell that the fan blades were dragging on something.
I contacted Ian at 24/7 and he said it should be an easy fix. I did ask about voiding the warranty if I took the cover off myself, but never did get an answer.
Although not happy that I was having to fix a brand new, rather expensive piece of equipment upon delivery, I took off the front cover.
Inside I found that the build quality was awful.
The green toroid with the blue and pink wires is not secured to anything, and it's crushed the side of the very thin plastic ducting pushing it into the fan, hence the code.
I ended up using cable ties to keep the torroid away from the ducting, but if you look lower there's an orange disc capacitor that is bent over itself, probably from being hit with the torroid.
This means that the units are not tested at the factory and there seems to be no quality control or final inspection.
will you wire those all in parallel? I had *thought* I read it's not good to put more than 5 batteries in parallel (but I've also read you're not supposed to step on a crack in the sidewalk...)Right now I have on order two 48V 16s 280AH sets; one from Amy Wan and the other from the Lishen-Eve store (?)
So approx 26KW of batteries coming. I may need one or two more sets to get 52AH's.
Home is mostly unoccupied (so I would not be there to shut anything off). Why is there no auto disconnect for over voltage?You can add extra panels to a mppt controler but the controler will only put out its max amps , but you will get to full amp out put earlier and latter in the day . I’m sure you can go over by 25% or a little more , I’m over by 500watts on my fm 80 .
If possible I would work with the 100 year cold average -39 is cold but you could just turn your solar off at nite and turn it back on when it warms up later in the morning .
My cold temp is -27 and I’m rite there at -27 so if I’m sitting @ - 15 before bed I’ll walk over an kill the solar and turn it back on in the morning after looking at the temp .
You can allso figure your winter watts will be about half what you get in summer so in theory you can allmost double
your solar panels for winter on one charge controller and just turn them off in the summer .
I have 4500 watts and see 3700 watts at 12 noon in July At 12 noon on dec21 I can see 1800/2000 watts max
