Dforster67
- Feb 2, 2021
- 60
I finally got the skybox installed. I went through the quick start and got everything setup and turned it on. The only thing connected currently is the grid inputs.
I am a little lost on the rapid shutdown section. It states that there should either be a rapid shutdown device or a factory installed jumper or you will get a fault. I currently do not have a rapid shutdown device installed. There is no jumper and of course I am getting a rapid shutdown fault and no AC output on my AC out terminals.
The instructions are not clear on if the "factory jumper" is already installed or should be included and has to be installed, or if I just jumper the terminals myself. The manual is not very thorough at all and I can't find anything on google or anywhere about this elusive jumper or how to install it.
I know a couple of you have the skybox and can probably help out!
Thank you!
Thank you!
