Hello, We purchased a well built ~700ft cabin in south central Washington last summer. This cabin was outfitted with one 110W panel leading to 2 6V batteries in series which provide (I believe) 200A hours of power. This is what I know and below I have my questions:
-There are two circuits one 15A which goes directly to a solar fridge which works well, the other is labeled as 10A
-The Xantrex charge controller is pictured below
-I've included my diagram with my understanding of the solar systems set up (note we do NOT have an inverter installed at this time)
-There are wired LED lights that all function well in the house
-There are traditional outlets which does power one floor lamp with and LED light
-There is no inverter in the system so my understanding is that everything is on DC
Our needs are as follows:
-Functional outlets for phone charging at minimum and ideally a laptop
-Ability to operate a water pump from portable water containers inside via outlet or hard wired
-Ability to power hot water heater
?So do we simply need to add an inverter to the system 'down steam' where the 15A circuit can still feed the fridge and the 10A inverted power can supply everything else.
?Is there a way to do this with everything being DC still, yet still have the easy plug in ability like a traditional AC set up
We've had sufficient power with this system and while reading through the posts it should like 24V systems are 'the way to go' I don't have a lot of time to retrofit this one and really want to be able to get the outlets to work for our appliances and have warm water over a weekend.
I know I have a lot to learn and I apologize if this is similar to a previous post that I had not found yet.
Thanks in advance for your advice.
