gray webber
- Feb 4, 2022
- 202
While I understand much of the solar issues, some component ratings do not compute for this newbie. I have been introduced to the term over-paneling. While this May seam easy to understand as to charge controllers, the manufactures only state max watts for a battery bank voltage.
My question: Will a charge controller be damaged if you feed more panel watts into them then rating or is their max rating the most they will convert into useful charging?
If they are not damaged then overpaneling May be good for cloudy regions that need extra PV for lean times.
I hope I explained my question right?
Thanks!
Thanks!
