Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,508
FETs, inductor, diode would have a maximum current limit. Excessive heating at higher current.
Switching power supplies can run off a battery (thousands of amps available) drawing just what they need to power the load.
Some have a problem that with low input voltage they draw excessive supply current trying to power the load and burn up.
MPPT charge controllers typically draw all the power available from PV while charging battery in CC mode, then switch to CV mode and draw less from PV.
But, the MPPT algorithm runs PV voltage up and down to see what delivers most power. That's one time where it should be careful in case available power exceeds the input or output current it can handle.
Even if MPPT was settled at some operating point and clouds suddenly cleared, that shouldn't increase current through inductor. That ought to be under algorithm control. Maybe uP decides what "on" time for the transistor my examining current sensor, and there isn't hardware or real-time response monitoring max current?
Some designs are more bullet proof than others.
We put in fuses or breakers, but sized 25% over and they take time to blow. Protection has to be designed into the product.
