Hello group and thank you for allowing me to join.
Background: I'm not new to electronics nor to solar systems. My entire system is DIY but lead acid. I have built it for a factory I'm building here (garment cut and sew for two production lines and also my house on property). We have hundreds of PV panels into various charge controllers of different manufacture but each CC has it's same PV type/mfg and orientation for that unit. We have a lead acid battery bank with Maxwell boostcap3000 ultracaps/supercapacitors for surge allowing the charge controllers to handle well quick power surges and reduce battery stress. Problem is battery bank is about 7 years old and not true deep cycle instead n200 size "solarmaster" batteries made in Philippines for a 1200aH bank. They are completely shot/worn out.
I want to build my own LiFePo4 bank so I can go completely off grid 24/7. I'm working on de centralizing some of my power requirements so installing allot of solar lights around property/buildings, making small setups for NSS brand DC brushless fans with battery input where solar goes, working on making a standalone system for our CCTV (3 TV's, 3 systems, 41 cameras) etc etc. But our inverters are all Outback. Our non critical is 4 pieces of 3500 watt Outback in series parallel. Our critical (house) is old sealed 2500 watt outback sealed (and yes they no longer can handle the full rating not likely old capacitors inside but not good enough ventilation needing improvement.
So with hundreds of PV panels I can get between 30kw and 40kw at 27.2vdc but never need it so my panels are basically overdone to make up for cloudy/rainy and early as well as late as possible production. We do have generators (two Denyo 25kva into a bank of 3 parallel meanwell supplies giving 9kw DC at our battery voltage when needed but really not ever needed).
My big concern is not if this system works as I've been running it and constantly expanding it for 7 years now but being new to LiFePo4 the massive amount of panels exceeding the maximum charge current into LiFePo4 DIY battery banks. I read on internet some brands limit both charging and discharging current. I really need someone to "elmer" me (HAM radio lingo for teach) so I don't have a catastrophic disaster on my hands. Too late to change my 24v system but I've got so much copper it is rediculous so I can handle hundreds of amps.
Apologize for being long winded on the background but felt I need to get it all out in the discussion.
Best regards and many advanced thanks,
Mike
Mike
