chuckpfaff
- Aug 26, 2021
- 2
Hi there.
I am experiencing high temperatures at the cutoff switch when my system is under load.
I have a 13.2 kWh 24VDC battery bank and 4000 Watt 24VDC Giandel Pure Sine Inverter
https://www.amazon.com/gp/product/B07D1LRKY5
The cutoff switch is a Blue Sea 9003e rated at 350 amps continuous.
https://www.amazon.com/dp/B0844QCXK6
I am using 1/0 gauge wire with very short length cables, most under 1ft, longest run is 3 feet from battery bank to the bus. All lugs are are soldered to the wire.
When then inverter is providing about 1.65kW AC the temperature at the cutoff switch gets up to 130 degrees Fahrenheit after 30 minutes.
If I take the cutoff switch out of the system it doesn't heat up nearly as much.
I have noticed a voltage drop of less than .5 volts at the cutoff switch when it is under load.
No noticeable voltage drop when using less than 800w AC.
Temperature of the wire is much cooler everywhere else in the chain.
Any suggestions would be greatly appreciated, I am at my wits end.
I have attached a picture of the system.
Thanks,
Chuck Pfaff
Thanks,
Chuck Pfaff
