I recently upgraded my camper to 280ah raw cell lithium batteries with an Overkill BMS. Everything is working great except for when I start my microwave, the BMS reboots, dropping the load in the process which resets everything in the camper including my Ali SOC shunt battery status. When I look at the BMS app afterwards there are no errors. I have measured the max current with a Fluke clamp on meter and it records 91 amps but I am guessing there is quick large inrush current that is not being captured. I calibrated the BMS per the Overkill instructions and I tried increasing the discharge over current protection from 130A to 140A, but the problem persists. If I drop the microwave power to 50%, I can prevent the reset, but this is obviously not a great answer. To solve this problem, I could replace the BMS, but I really like the features and configurability. Another option would be to wire the inverter directly to the battery and bypass the BMS but then I will not capture the true SOC on my Ali shunt. My third option is to install a BMS bypass relay that would be controlled by a push button next to the microwave to get past the initial current surge. Think of it like a clothes dryer start button. This would maintain my SOC accuracy and keep the BMS protections once the button is released. The question is, what is the impact of doing this on the BMS? The BMS is essentially a solid-state switch so theoretically this should work, and it did in my testing but I have no idea what the long term impact would be. I would appreciate any suggestions. I have attached a wiring diagram and screen shots of my BMS settings.
