moonlitsouls
- Jan 4, 2021
- 424
I have no idea I just plug the battery in to my RV and the charger , solar charge controller, shore power connections charge it up.What voltage will you be charging the battery to? Looks like you will be charging at less than 14.6 volts.
I checked my user manuals for both the solar charge controller and the progressive dynamics converter and I don’t think either one of them are programmableYou need to set your solar charge controller and line voltage charger up to work with your BMS settings.
I set my SCC and line voltage charger to operate just below the BMS thresholds.
Awesome, I was confused about what you meant that I would be charging to less than 14.6 volts. I thought maybe the settings I had copied were too conservative.Settings look fine. The charging and maintenance voltages of both the solar and converter seem fine while in use. Probably best to disconnect for storage.
The Over Current is the factory setting at 130 amps is set to protect the BMS from over current. Will disconnect if current excess for 10 seconds and reconnect after 32 seconds. This will give a few seconds of surge performance without damaging the BMS.
Thanks for the helpThe reduced cycle capacity and the cell full value seemed to imply your charging voltage might be a bit lower. So I was looking at the balance start voltage same as the cell full voltage and was wondering if your actual charging voltage would be high enough to trigger cell balancing. All is good at 14.4 volts.
If you click on the ? next to the setting, the setting is explained. I would leave it alone.Question why is my cell full voltage only 3.4 ? I can raise to 3.6 no?
