Need some help figuring out the Overkill BMS and Midnite charge controller.
I seem to lose the ability to solar charge the Lifep04 pack once the Overkill BMS low cell voltage trips. I need the ability to have the system to start charging once the solar power comes available. As the system is in a remote location, accessing the BMS is not possible once the power is off.
I'm not sure if this is an issue with the BMS (not allowing a charge current once low voltage is tripped) or an issue with the Midnite charge controller stopping charging current if it does not detect a battery (since the BMS has cut the power from the pack).
Trying to figure out how to set the BMS and the Charge Controller to work after a low voltage trip. Thanks,
