Hi Guys, I have 8s BMS with EVE 304AH cells. Initially balanced all cells in parallel to 3.6v with external power supply until current draw was few mili amps. The setup was working fine for several months, then I didn't check for a month or so. Now cell 8 is always .1v higher, I confirmed by removing the balance connector and checked voltage on the pins, they are fine 3.29#v all of them including cell 8. The app shows 3.37x. I swapped cell 8 with 6 and still the cell #8 ( which was 6 and showing correct voltage before) is .1v higher in the app, so I think its a software issue. I only have Bluetooth dongle. Any idea ?
