Hi,
would it be possible to use the Max charge current option in the Overkill (4s) BMS as a current limiter instead of installing a DC/DC charger?
My battery now pulls up do 100A from the alternator, which is not desirable.
I was wandering if limiting the current to 40A in the bms would be a solution, or that installing a dc/dc charger is the only (good) sloution.
Best regards,
Dick Martens
Best regards,
Dick Martens
