lukathonic
- Jan 8, 2022
- 3
I'm setting up a solar system for our shallow well pump. It will mostly be used during power outages (typically less than a day, but you never know), but if it works well I'll just disconnect the AC.
The shallow well pump is currently powered by a single 120v outlet. I have a single 12v dual purpose marine battery (group size 27) hooked up to a 2000w inverter. The battery is topped off by a trickle charger right now - I'll be replacing it with a solar panel later once I have the battery working properly.
My problem is that when the well pump runs, the inverter's alarm goes off. That either means a short or overload. I have a kill a watt electrical plug monitor that shows a draw of around 10amps while it's running.
Is it possible that the inverter is overloaded because the well pump is drawing more than 2000 watts when it first turns on? I've always thought that 1800w was the max on a 15a 120v circuit ...
Thanks for your help.
Luke
Luke
