emcvay
Hi,
I've been debating over paneling for a little while now and as someone who's watched many of Will Prowes videos I thought I'd pop in here and toss this out:
If you install a solar array or string that can produce more power than the charge controller can utilize how can that possibly provide MORE charging power to the battery bank than just installing a larger charge controller that is properly sized for the array?
In my mind there is power available as soon as the sun hits the panels in sufficient amounts to generate something the SCC can use. It then continues, essentially in a bell curve throughout the day until it hits peak and then drops off to nothing. Of course, on a cloudy day this curve might be warped quite a bit as the clouds block out the sun at differing degrees however it still follows a predictable path of a start and finish point and a peak at some point during the day.
A smaller charge controller can only utilize so much power from what is available and a larger one, while able to utilize the same amount of power at lower levels can utilize MORE power at the higher levels.
Setting cost aside and all in one systems aside, on a theoretical basis I see no advantage in using a smaller charge controller over a larger one (if measured in max wattage on the input side). I realize the efficiency calculations will appear to make the smaller unit more efficient but that does not equate to making more power available to charge batteries on a cloudy day.
So, how is it that a 2000w max input charge controller can possibly utilize more power from a 2300w array that say, a 2500w max input charge controller could?
