I've tried 3 different inverters using Renogy and Ampretime Lifepo4 batteries, and they all trip the overvoltage alarm when the batteries are charged above ~13.2 volts. The invertors are just cheap ones from walmart and harbor freight.
The recommendations on both batteries are to charge between 14.2-14.6. Is there a list of invertors that will work with that high of a voltage? Even if I set the charge voltage cutoff at 14.2, the inverters still trip
All 3 inverters are fine and don't trip the overvoltage alarm if I only charge the batteries to ~13.0v, but then I'm not fully charging the batteries
Is this just due to most invertors being designed for lead acid? If so, are only programmable invertors truly compatible with lithium batteries?
