OffTheWall503
- Jan 11, 2022
- 5
Hey everyone! Having an interesting issue with my two 12v 206Ah batteries wired in parallel. I am using an AIMS Power 2500w LF Inverter/Charger (PICOGLF25W12V120AL) set to charger profile #4, which is within range of the recommend bulk/float settings from SOK. Once at full charge, the inverter will switch to float and then beep continuously, troubleshooting has indicated that it’s telling me it’s “over voltage.” Also running a Renogy solar charge controller from panels to the batteries and the indicator light is also telling me the same when this occurs. Doing some further testing with a multimeter, voltage would get to 14.4, spike to 16v briefly then go into a float state. I’m not sure if this is how it’s supposed to behave, but I have a feeling the BMS is getting tripped somewhere. This also makes me wonder if I need to change my solar controller settings for these batteries, however I am switching to a Victron SmartSolar MPPT 100/20 this weekend.
After doing some research, people have started that the “AGM 1” may be the better choice of a profile, however it’s on low end of the recommended specs and I’m not sure how long absorption works in this profile.
Two other threads I found for reference:
Thanks!
Aims Power inverter/charger with SOK 206ah batteries - will these charge properly?
I'm looking at building a power system for a travel trailer. I am comfortable with almost everything in the system, but have some questions on an AIMS Power inverter/charger and their use with lithium batteries. Essentially, this 2500w AIMS Power inverter/charger looks attractive due to the...
diysolarforum.com
Charging LiFEP04 with AIMS inverter/charger
Hi, I'm using an 2000 watt AIMS inverter/charger that was made before LiFEP04 batteries became popular, circa 2013. It doesn't have a setting for LiFEP04 batteries. Here are the available profiles, from a photo of the unit: In response to a similar inquiry, @snoobler suggested using the AGM1...
diysolarforum.com
Thanks!
