I have the Giandel 2200w inverter and the Victron 100/50 controller with 2 SOK 100 amp 12 Lithium batteries. 4 100 watt solar panels in series with max voltage of about 89 volts. When the batteries are going into Absorbtion mode the voltage goes to the setting of 14.6. I did see a max voltage of 15.2 I think in the history. Problem is when it goes into Absorbtion the inverter gives a OverVoltage fault. I turned the voltage setting down to 14.4 and it seems the problem has gone away. This inverter says max voltage is 16 +/- .5 volts. Anybody else have any experience with this.
