wiseacre
..directed at domestic vendors packing cells for shipping
I just got a box of cells where the welded posts poked through the box. It was a close call, the tops of the plastic post covers were mangled but thankfully the posts and cells were undamaged. If it wasn't for the excessive amount of bubble wrap around the individual cells and foam lining the box it would have been a sob story indeed.
Thinking about it, I suggested using foam board insulation cut to fit the cell tops with holes for the studs then bubble wrapping as usual.
1 inch might be over doing it but using the foam board would spread any impact over a larger area instead of the small pressure points of the studs.
another piece of board over the group of cells might be overkill.
The insulation foam board is much much less prone to compression than the foam sheets I see being used to line boxes
