Venezuela Solar
- Dec 6, 2019
- 146
I'm planning to use this (see link) second hand packs to make an small mini ups to back up 3 routers and a modem, I know that this packs have more than enough energy for routers, but, the thing is that some times we loose power 6 to 8 hours and last time was 14 continuos hours and if things go bad it could be days.
So the real question is that this packs ranges from 12v (3v per cell) cutoff voltage and 16.8v fully charged, the power brick of the routers say 12v1A , do I need a buck converter? Or a buck/boost converter (I haven't be able to find one of this that convinces me)
Also, every 16.8 charger that I found looks like a cheap 2 uses power brick.
If I were to charge this pack with a 30-40w solar panel, would it need a charge controller, MPPT I guess it that case.
I plan to use 5.5mm barrel plugs for easy connections
Thanks
Thanks
