Panel angle formula?
nicoloks
Howdy,
Just wondering if anyone knew where I could find a formula or online calculator, etc, to help me calculator potential production losses in my portable panels from their angle relative to the sun?
The panels are meant to be perpendicular to the sun, but how do I calculate potential loss if I put my panels out for the day and go for a walk and they end up being 35° off.
Thanks for that. Didn't so much want an optimal angle calculator, more a way of discerning what the production fall off is the further off that optimal angle you get.
It’s not linear because it’s per-square-inch of exposure based.
So there’s not a constant.
Calc one 90* arrangement, and then calc you 35* off, subtract the two for a difference. There you have it.
Use ptwatts. It's geared for permanently mounted solar panels but will give you an idea for your camping setup. Plugin different angles to see the effect.
Howdy,
Usually your latitude is the same angle for a fixed panel angle. You can use a calculator, but really you could go out now as we just passed the spring equinox and use the soup can method with a leveling protractor on the base to get degrees.
If you are looking for tilt that is adjustable, I suggest using this calculator for your location and try various tilt angles for winter/ summer solstice and spring/fall equinox. I found that calculator more accurate than PV Watts.
This isn't anything 'high tech' - but back when I just used two panels, some superstrut and a dish tv azimuth mount for each one on a pole - all I did was right about 1-2 o'clock I just held a water bottle to each panel and used the tilt to eliminate the shadow.
Howdy,
Its basically what the sun can "see" when its looking at your panel.
If the panel is directly facing the sun its obviously 100% of the area of the panel.
If the sun is completely edge on, its theoretically zero.
Cosine of 0 degrees = 1.0
Cosine of 35 degrees = 0.812
Cosine of 90 degrees = 0
If the sun is off by 35 degrees you will still get about 81% of max.
Even at 45 degrees off, its still about 71%
Its not as critical as many people expect.
It's the Cosine of the difference of panel to sun angle.
Totally depends on the latitude the panel is at. Since it is not a linear progression those at high latitudes will see a very large difference in output with small angle changes in the Sun.
That is not what he is asking.
He wants to know how much he loses if if the panel is 35 degrees off pointing directly at the sun.
Thirty five degrees of aiming error is thirty five degrees, no matter where you are.
Its a very simple question, and you do not need a sun chart to answer it.
My panels are vertical year ‘round because in winter I don’t want to be chasing snowflakes with a squeegee to get my measly 4.7 watts of charging. In summer I have so much more solar than needed that I’m charged sufficiently by 9am so I just have them vertical.
I have one array with 400W of panels that face SE. In the afternoons there is no sun on them of course; yet with good sun summer or winter I still see ~150W or more from that array.
Sure, I’m not ‘maximizing production’ whatsoever. But I agree: it’s not as critical as many people expect.
I just accepted the ‘loss’ in winter because I can’t be here all day to clean the snow off angled panels. I see arrays all over the area that are tilted; some stay snow covered for days or even weeks sometimes. This would not work out for me.
You take a beer bottle and place in on the panel at 12.00. Angle is perfect if you see no shadow.
Howdy, Just wondering if anyone knew where I could find a formula or online calculator, etc, to help me calculator potential production losses in my portable panels from their angle relative to the sun? The panels are meant to be perpendicular to the sun, but how do I calculate potential loss if I put my panels out for the day and go for a walk and they end up being 35° off.
Go to pvwatts input different tilt scenarios, compare
