Garage Solar
- Jul 24, 2020
- 26
Hi all -
The Inergy Flex 1500 with two batteries has about 2000wh capacity. The MPPT controller in the unit has a 90v limit, and limits input amps to 30. What is an ideal wattage/voltage/series-parallel panel array? The Flex with one battery has a "kit" option with four 100-watt 12v panels. I want to set up an efficient set of panels for recharging a Flex with two batteries, but eight 100-watt panels seems like a lot to deal with in terms of space and wiring.
What about three 200-watt 12v panels, rated at 11.6 amps/17-18v? Both series and parallel hookups seem to be within the Flex's voltage/amp limits.
All suggestions appreciated!
GS
GS
