Wits' End
Old guy, wanting to learn new tricks.
If this is covered elsewhere, please direct me.
Advantages and disadvantages of series, parallel, wiring panels, when it comes to loss in one panel or a part of a panel. Due to external shadow, surface obstruction (bird droppings) or electrical issues.
I have 18 400W 50V OC BiFacial, and MPPT 250v 5000W max.
12 panels "East array" [side of roof, all same orientation] 4S3P
6 panels "West array" 3S2P, as yet unnamed MPPT SCC.
My main question, what are the disadvantages of the 4S3P? Would 3S4P be better? If part of array is shaded or not producing as highly.
2nd question: Does it make sense to run one of the 4S3P, parallel legs to a separate breaker? As under possible conditions, this array could produce in excess of 5000 watts, they are BiFacial.
Should I run positive and negative from PV, through breaker? Or just positive?
As I have two separate power runs from PV to SCC, I assume I have to put separate "lightning arrestors" on them.
LA are "better" than surge protection devices, at reducing damage from massive electrostatic discharges?
