I just purchased the MPP LV 5KVA-48v and I have 20-100watt 12v Renogy panels. My question is what is the best configuration series/parallel for the unit. My confusion is over the 48v requirement (these Renogy panels are shown as 12volts but operate around 20v 5amps. I had planned on having 4 or 5 strings consisting of 4 100 watt panels in series which would amount to 48 volts and 5 amps for each string. Then parallel the strings into PV1 and PV2 which would then be 48 volts at 20 amps. Your assistance is deeply appreciated. Here is the link to the MPP LV5KVA-48v http://www.mppsolar.com/manual/SPLIT PHASE LV/LV5048 split phase manual-20191024.pdf
