Hi,
considering I'm using an oversized Inverter/MPPT(Growatt SPF3500ES) with only x4 450w Panels (1800w), would I have efficiency problems on sunrise/set and cloudy weather?
The Panel's Max power voltage is 41V ( x4 = 164V)
The MPPT minimum voltage is 120V
While in good weather conditions the system should work normally - could I have problems hitting the MPPTS minimum voltage requirement when its cloudy?
Is it better to find an MPPT with lower voltage startup?
I'm not too sure how does the MPPT but my fear is that if the voltage is dynamic could it go under the mppt requirement and not generate any power?
Cheers,
Nezek
Cheers,
Nezek
