littleharbor2
After 75 posts It must've been brought up but why don't you cut off the MC-4's and crimp on new ones?
Has he checked to see if the + and - reads correctly from the cable ends?Unless (+) and (-) are reversed for one panel, as was proposed earlier.
With B and C connected together, remove all junction box covers. Check for continuity between B and C, and check all voltages (un sunlight)
I'm going to try that but to me, it's a moot point. The fact that I can get voltage from the panel alone and even with extension cables connected means there's nothing wrong with the connectors. But, it's worth a try so I'll do that when I get out there again.After 75 posts It must've been brought up but why don't you cut off the MC-4's and crimp on new ones?
Did you make sure the male end from the panel is positive and the female connector is negative?That's correct but on both ends meaning, either positive or negative.
As soon as I connect another panel on either side, there is no more connectivity in the two panel string.
It's floating, zero, nothing .
It just plain made no sense when I was wiring things up but that's what it is.
As I said, I'll check it again even though I've checked it multiple times.
Yes, he has . But he'll do it again because there's nothing wrong with checking more than 3, 4, 5, or more times when it comes to something that doesn't make sense.Has he checked to see if the + and - reads correctly from the cable ends?
If the connectors are reversed you would need to crimp on new ends anyway.I'm going to try that but to me, it's a moot point. The fact that I can get voltage from the panel alone and even with extension cables connected means there's nothing wrong with the connectors. But, it's worth a try so I'll do that when I get out there again.
I definitely want to update this post once this is solved, if it is because it might help someone at some point as a seemingly rare, if ever, occurrence.
I can't recall specifically now but I'll double check that too.Did you make sure the male end from the panel is positive and the female connector is negative?
That could TOTALLY explain the problem your having if they are reversed.
Yes, I took that into consideration also but all of the connectors for the extensions are the same.The other way that could be unseen is if the connector is sliding back when it is inserted into the other panels - i.e. your patch cables may have different size slightly metal bits inside so they don't mate properly with similar size.
Do you have a DC clamp meter? I wonder what the result would be if you just plugged the panel connectors together and put a clamp meter across it in full sun. It should be Isc or close, but if the runs on the front have issues or it can't mate with itself you would get a lot less.
Another thing I noticed on all of my panels is that the male connector which is the positive lead has a red oring on it which I took as meaning positive too.I can't recall specifically now but I'll double check that too.
Female looking connectors looking like males and vise versa is an interesting thing they came up with .
I've been meaning to order a DC clamp meter but don't have one at the moment.
Yes, I know about the O rings but never noticed if they are different colors. I'm sure some fall for that unfortunately.Another thing I noticed on all of my panels is that the male connector which is the positive lead has a red oring on it which I took as meaning positive too.
This is the one I plan on getting. Just have to try to put some things on hold as I've been spending like a crazy man lately.I just added a new one under tool the answer thread in my sig line - it is very cheap import off amazon so I can't promise accuracy - think cheaper than harbor freight. but I expect it would give some indication
Hi, sorry, was not sure what else to add.
Yes, I'm only measuring open voltage at the moment, no load since I'm just setting up the strings right now.
When I bypass it in my string, the string is as it should be. As soon as I connect this panel to another in series, I get zero voltage across the two connectors, -/+/
But the OP said there is no load.Still likely to be reverse polarity or exceeding max volts on controller.
Close, the weird panel is #2 in your image. There are 7 total per string. At the moment, that panel is bypassed.Based on my understanding of what the OP has said, this is what is happening:
Panel 0 is the one in question. But I think there is still some information that I don't know about.
Maybe post pictures of the setup and exactly where the voltages are being measured.
So total VOC reading is 180vdc? And the panel string has no load?Close, the weird panel is #2 in your image. There are 7 total per string. At the moment, that panel is bypassed.
... from my diagram in post #75 the voltage of AB should remain the same, whatever is connected to it, if no current is flowing.That could TOTALLY explain the problem your having if they are reversed.
this ^^^.Also he did not clarify which two connectors he is measuring from.
That is why he should show exactly his setup and where he is measuring.
Are you saying you like this one over the Klein or just that it's cheaper? Have you used both? The one you're showing looks interesting.
