Hi. New to solar but have working 12V -250 setup and building a 24V 1000W setup. One question is solar array and strings.
One panel or 20 panels is a array?
Two wired in series or 2 parallel is a string?
4 panels -both wired series then all in parallel is two strings?
This configuration only double volts and amps of one panel output, even tho 4 panels, two pairs are wired series and only doubles amps, even tho 4 are wired in parallel?
But if I wired all 4 in series, volts per panel x 4 not 2 if also in parallel?
I plan to confirm output of different configurations with watt meter before wiring to controller but don’t have it in front me.
Thanks
Thanks
