amarsinha
Hi everyone,
I'm trying to install my first solar panel system and am trying to figure out the specs, and would appreciate if someone could confirm if I am on the right track with sizing the system because some of it is not lining up to my eyes.
I am trying to power two 1500 W greenhouse heaters - https://www.amazon.com/dp/B06XCJ7Q3S?psc=1&ref=ppx_yo2ov_dt_b_product_details
They will be heating two greenhouses in the winter when I receive around 4-5 hours of peak sunlight per day, and will run a total of approximately 6 hours.
Taking that into consideration and accounting for 3 days of autonomy, I have calculated the following:
And using that I would be able to calculate the size of the solar array as:
If someone can validate my calculations that would be really helpful, as I'm really curious that if this is the case, how houses can run off of solar power with what seems like much less than 30 panels installed on their roofs.
Thank you!
*Updated to account for inverter losses.
- 1,500 W x 2 = 3,000 W x 6 hrs = 18,000 Wh
- 18,000 Wh * 3 DoA = 54,000 Wh
- 54,000 Wh / 0.85 ~= 64,000 Wh (accounting for inverter losses)
- 64 kWh / 4h of sunlight = 16 kW
Thank you!
